ChatGPT App on MDM managed iPads Unable to Install "ChatGPT" JAMF pro
  • August 14, 2023
  • 5 replies
  • 64 views
CLG
Hi All,
Have anyone tried to install ChatGPT on  MDM manage devices(I'm using JAMF pro )?
When I tap on the installed app I get an error  as below with two options VIew in store or OK
you must purchase this app to install it.
      View in App Store
               OK
I have pushed the app to selected devices it is available in the Self-service and shows as "Reinstall"
This is urgent have to configure this before Wednesday
Help will be much appreciate
Thanks
Best answer by CLG
Some IPad was fine it got installed although those I pad didn't have the latest iOS update.
There were a few needs to Update the iOS 16.6 and after several restarts, it got installed
It's very random can't give a proper answer but I manage to sort out the issue.
MatthewGV
  • August 14, 2023
Purchase via VPP and assign to the devices you want.
CLG
  • August 14, 2023
Could you explain more?
Normally what I did /do is go to the Scholl manager and purchase the app from there
Then come back to the Jamf Pro (the app will be available automatically )  from there I push for the devices.
mvu
Forum|alt.badge.img+21
  • August 14, 2023
In Jamf, did you check off the box to "Assign Content Purchased in Volume"?
CLG
  • August 16, 2023
Yep it was already checked
CLG
  • August 16, 2023
