WGM GUI
  • October 13, 2009
  • 8 replies
  • 24 views
Does anyone know where the "..." button pulls names from in the Computer Groups tab in Workgroup Manager? I've deleted computers and when I click the "+" to re-add them they're not there, but they're listed with the "..." button. Curious.
Jeffrey A. Strauss
Department of Educational Technology
Systems Administrator
Loyola High School of Los Angeles
1901 Venice Blvd.
Los Angeles, Ca 90006
(213) 381-5121 x265
Please consider the environment before printing this e-mail.
Forum|alt.badge.img+31
  • October 13, 2009
You mean computer groups? The names are imported by doing an
authenticated bind. I am not sure what you are exactly asking, can you
post a screen shot?
Thomas Larkin
TIS Department
KCKPS USD500
tlarki at kckps.org
blackberry: 913-449-7589
office: 913-627-0351
stevewood
Forum|alt.badge.img+38
  • October 13, 2009
While I cannot find any concrete evidence (i.e. no manual or web link), I
believe this list is generated via Bonjour.
Steve Wood
Director of IT
swood at integer.com
T 214.758.6813 | F 214.758.6901 | C 940.312.2475
stevewood
  • October 13, 2009
I stand corrected. I should have waited for the page to load:
http://support.apple.com/kb/TS2079?viewlocale=en_US
Appears there are two conditions:
- The client is bound to the server using Directory Utility or - The client receives LDAP information via DHCP (also referred to as "option 95")
Steve Wood
Director of IT
  • October 13, 2009
Bonjour on your local computer I thought.
Brad Rellinger
Technology Specialist
Anthony Wayne Local Schools K-12
aw_aca_bre at nwoca.org
  • October 13, 2009
Well I am fairly certain it has to be an authenticated bind with the
computer's name...
Thomas Larkin
TIS Department
KCKPS USD500
tlarki at kckps.org
  • October 13, 2009
In any case, here are the screenies.
Matthews02 shows the entire group without Matthews01 (the one I delete) using the "+" button Matthews01 shows Matthews01 (the one I deleted) appear using the "..." button
On 10/13/09 10:32 AM, "Thomas Larkin" <tlarki at kckps.org> wrote:
Well I am fairly certain it has to be an authenticated bind with the computer's name...
Thomas Larkin
TIS Department
KCKPS USD500
tlarki at kckps.org
  • October 13, 2009
I'm thinking this issue is a reason why this particular computer isn't receiving appropriate management from the server... Every time I try to perform an authenticated bind to the server I get an error saying the computer is already there and I can't overwrite. Dunno if it's related, but I'm still trying to figure out why some computers won't receive prefs.
Thomas Larkin
TIS Department
KCKPS USD500
tlarki at kckps.org
  • October 13, 2009
If you delete a computer and are running OD replication you probably
have to delete it, then force a replication then readd it in, maybe?
