So I have a network payload that setup the 802.1x wifi and works fine.
However, If a user go in and manual remove the Wifi from the stored network list on the mac and afterwards want to connect to the network again, the config is not there anymore - EVEN the config profile still is on the mac
If I remove the config profile and add it again, it is possible to connect again. Is this working this way as cannot understand why it will not connect after a wifi has been removed
