Hi - is the best option to determine if a mac is filevault 2 encrypted using an EA with this command:
fdesetup status ?
thanks.
Here's the EA that I'm using. I've this pieced together from a both EAs that Rich Trouton created.
CORESTORAGESTATUS="/private/tmp/corestorage.txt"
ENCRYPTSTATUS="/private/tmp/encrypt_status.txt"
ENCRYPTDIRECTION="/private/tmp/encrypt_direction.txt"
osvers_major=$(sw_vers -productVersion | awk -F. '{print $1}')
osvers_minor=$(sw_vers -productVersion | awk -F. '{print $2}')
# Checks to see if the OS on the Mac is 10.x.x. If it is not, the
# following message is displayed without quotes:
# "Unknown Version Of Mac OS X"
if [[ ${osvers_major} -ne 10 ]]; then
  echo "<result>Unknown Version Of Mac OS X</result>"
# Checks to see if the OS on the Mac is 10.7 or higher.
# If it is not, the following message is displayed without quotes:
# "FileVault 2 Encryption Not Available For This Version Of Mac OS X"
if [[ ${osvers_major} -eq 10 ]] && [[ ${osvers_minor} -lt 7 ]]; then
  echo "<result>FileVault 2 Encryption Not Available For This Version Of Mac OS X</result>"
if [[ ${osvers_major} -eq 10 ]] && [[ ${osvers_minor} -ge 7 ]] && [[ ${osvers_minor} -lt 13 ]]; then
  diskutil cs info / >> $CORESTORAGESTATUS 2>&1
    # If the Mac is running 10.7 through 10.12, but the boot volume
    # is not a CoreStorage volume, the following message is
    # displayed without quotes:
    # "FileVault 2 Encryption Not Enabled"
    if grep -iE '/ is not a CoreStorage disk' $CORESTORAGESTATUS 1>/dev/null; then
       echo "<result>FileVault 2 Encryption Not Enabled</result>"
       rm -f "$CORESTORAGESTATUS"
    # If the Mac is running 10.7 through 10.12 and the boot volume
    # is a CoreStorage volume, the script then checks to see if
    # the machine is encrypted, encrypting, or decrypting.
    # If encrypted, the following message is
    # "FileVault 2 Encryption Complete"
    # If encrypting, the following message is
    # "FileVault 2 Encryption Proceeding."
    # How much has been encrypted of of the total
    # amount of space is also displayed. If the
    # amount of encryption is for some reason not
    # known, the following message is
    # "FileVault 2 Encryption Status Unknown. Please check."
    # If decrypting, the following message is
    # "FileVault 2 Decryption Proceeding"
    # How much has been decrypted of of the total
    # If fully decrypted, the following message is
    # "FileVault 2 Decryption Complete"
    # Get the Logical Volume UUID (aka "UUID" in diskutil cs info)
    # for the boot drive's CoreStorage volume.
    LV_UUID=`diskutil cs info / | awk '/UUID/ {print $2;exit}'`
    # Get the Logical Volume Family UUID (aka "Parent LVF UUID" in diskutil cs info)
    LV_FAMILY_UUID=`diskutil cs info / | awk '/Parent LVF UUID/ {print $4;exit}'`
    CONTEXT=`diskutil cs list $LV_FAMILY_UUID | awk '/Encryption Context/ {print $3;exit}'`
    if [[ ${osvers_major} -eq 10 ]] && [[ ${osvers_minor} -eq 7 || ${osvers_minor} -eq 8 ]]; then
        CONVERTED=`diskutil cs list $LV_UUID | awk '/Size (Converted)/ {print $5,$6;exit}'`
    if [[ ${osvers_major} -eq 10 ]] && [[ ${osvers_minor} -ge 9 ]]; then
        CONVERTED=`diskutil cs list $LV_UUID | awk '/Conversion Progress/ {print $3;exit}'`
    ENCRYPTIONEXTENTS=`diskutil cs list $LV_FAMILY_UUID | awk '/Has Encrypted Extents/ {print $4;exit}'`
    ENCRYPTION=`diskutil cs list $LV_FAMILY_UUID | awk '/Encryption Type/ {print $3;exit}'`
    SIZE=`diskutil cs list $LV_UUID | awk '/Size (Total)/ {print $5,$6;exit}'`
    # This section does 10.7-specific checking of the Mac's
    # FileVault 2 status
   if [[ ${osvers_major} -eq 10 ]] && [[ ${osvers_minor} -eq 7 ]]; then
      if [ "$CONTEXT" = "Present" ]; then
        if [ "$ENCRYPTION" = "AES-XTS" ]; then
          diskutil cs list $LV_FAMILY_UUID | awk '/Conversion Status/ {print $3;exit}' >> $ENCRYPTSTATUS
            if grep -iE 'Complete' $ENCRYPTSTATUS 1>/dev/null; then
              echo "<result>FileVault 2 Encryption Complete</result>"
              if  grep -iE 'Converting' $ENCRYPTSTATUS 1>/dev/null; then
                diskutil cs list $LV_FAMILY_UUID | awk '/Conversion Direction/ {print $3;exit}' >> $ENCRYPTDIRECTION
                  if grep -iE 'Forward' $ENCRYPTDIRECTION 1>/dev/null; then
                    echo "<result>FileVault 2 Encryption Proceeding. $CONVERTED of $SIZE Encrypted</result>"
                    echo "<result>FileVault 2 Encryption Status Unknown. Please check.</result>"
            if [ "$ENCRYPTION" = "None" ]; then
                if grep -iE 'Backward' $ENCRYPTDIRECTION 1>/dev/null; then
                  echo "<result>FileVault 2 Decryption Proceeding. $CONVERTED of $SIZE Decrypted</result>"
                elif grep -iE '-none-' $ENCRYPTDIRECTION 1>/dev/null; then
                  echo "<result>FileVault 2 Decryption Completed</result>"
    # This section does checking of the Mac's FileVault 2 status
    # on 10.8.x through 10.10.x
    if [[ ${osvers_major} -eq 10 ]] && [[ ${osvers_minor} -ge 8 ]] && [[ ${osvers_minor} -lt 11 ]]; then
      if [[ "$ENCRYPTIONEXTENTS" = "No" ]]; then
      elif [[ "$ENCRYPTIONEXTENTS" = "Yes" ]]; then
          diskutil cs list $LV_FAMILY_UUID | awk '/Fully Secure/ {print $3;exit}' >> $ENCRYPTSTATUS
            if grep -iE 'Yes' $ENCRYPTSTATUS 1>/dev/null; then
              if  grep -iE 'No' $ENCRYPTSTATUS 1>/dev/null; then
                  if grep -iE 'forward' $ENCRYPTDIRECTION 1>/dev/null; then
                  if grep -iE 'backward' $ENCRYPTDIRECTION 1>/dev/null; then
    # on 10.11.x through 10.12.x
    if [[ ${osvers_major} -eq 10 ]] && [[ ${osvers_minor} -ge 11 ]] && [[ ${osvers_minor} -lt 13 ]]; then
      if [[ "$ENCRYPTION" = "None" ]] && [[ $(diskutil cs list "$LV_UUID" | awk '/Conversion Progress/ {print $3;exit}') == "" ]]; then
      elif [[ "$ENCRYPTION" = "None" ]] && [[ $(diskutil cs list "$LV_UUID" | awk '/Conversion Progress/ {print $3;exit}') == "Complete" ]]; then
      elif [[ "$ENCRYPTION" = "AES-XTS" ]]; then
          diskutil cs list $LV_FAMILY_UUID | awk '/High Level Queries/ {print $4,$5;exit}' >> $ENCRYPTSTATUS
            if grep -iE 'Fully Secure' $ENCRYPTSTATUS 1>/dev/null; then
              if grep -iE 'Not Fully' $ENCRYPTSTATUS 1>/dev/null; then
                if [[ $(diskutil cs list "$LV_FAMILY_UUID" | awk '/Conversion Status/ {print $4;exit}') != "" ]]; then
                  diskutil cs list $LV_FAMILY_UUID | awk '/Conversion Status/ {print $4;exit}' >> $ENCRYPTDIRECTION
                    elif grep -iE 'backward' $ENCRYPTDIRECTION 1>/dev/null; then
                elif [[ $(diskutil cs list "$LV_FAMILY_UUID" | awk '/Conversion Status/ {print $4;exit}') == "" ]]; then
                  if [[ $(diskutil cs list "$LV_FAMILY_UUID" | awk '/Conversion Status/ {print $3;exit}') == "Complete" ]]; then
if [[ ${osvers_major} -eq 10 ]] && [[ ${osvers_minor} -ge 13 ]]; then
# If the OS on the Mac is 10.13 or higher, check to see if the
# boot drive is formatted with APFS or HFS+
boot_filesystem_check=$(/usr/sbin/diskutil info / | awk '/Type (Bundle)/ {print $3}')
# If the drive is formatted with APFS, the fdesetup tool will
# be available and is able to display the encryption status.
    if [[ "$boot_filesystem_check" = "apfs" ]]; then
    # "FileVault is On."
    # "Encryption in progress:"
    # "Decryption in progress:"
    # If not encrypted, the following message is
    # "FileVault is Off."
    ENCRYPTSTATUS=$(fdesetup status | xargs)
        if [[ -z $(echo "$ENCRYPTSTATUS" | awk '/Encryption | Decryption/') ]]; then
            ENCRYPTSTATUS=$(fdesetup status | head -1)
            echo "<result>$ENCRYPTSTATUS</result>"
            ENCRYPTSTATUS=$(fdesetup status | tail -1)
    if [[ "$boot_filesystem_check" = "hfs" ]]; then
        # If the Mac is running 10.7 or higher and the boot volume
    # This section does checking of the Mac's FileVault 2 status if the boot drive is formatted with HFS+
            echo "<result>Unknown filesystem.</result>"
# Remove the temp files created during the script
if [ -f "$CORESTORAGESTATUS" ]; then
if [ -f "$ENCRYPTSTATUS" ]; then
   rm -f "$ENCRYPTSTATUS"
if [ -f "$ENCRYPTDIRECTION" ]; then
   rm -f "$ENCRYPTDIRECTION"
wow, thanks. pretty extensive!
@tranatisoc If you want a simple yes or no from the EA, then yeah you can build an EA from that basic fdesetup status command. if you want more extensive results, then @mottertektura's script is the way to go.
This is built into JAMF, no need to reinvent the wheel.
