Built a package for Final Cut Pro 10.3.2 update last year, using the App Store method as described on @rtrouton 's site here: https://derflounder.wordpress.com/2015/11/19/downloading-installer-packages-from-the-mac-app-store-with-appstoreextract/
Initial testing on my machine seemed to go fine, but when rolling it out to our test group, I'm seeing a number of failures where it appears to refuse to install as an upgrade. I'm getting the following in the logs:
Executing Policy Install Latest Final Cut Pro Caching package Final Cut Pro 10.3.2... Verifying package integrity... Installing Final Cut Pro 10.3.2... Installation failed. The installer reported: installer: Cannot install on volume / because it is disabled. installer: Final Cut Pro X is already installed on this computer. Open App Store to check for available updates.
Any clue how to force the file as an update? Appears to work fine to do a bare install, but I'm just trying to patch our existing FCPx installs.
