New to Jamf. I'm looking to change some settings in Notability for iOS to disable Giphy content from being accessed by students (as mentioned on this page from their website). I'm hoping it's something easily done on a page I can't find – can someone point me in the right direction? I've downloaded the .plist file but I can't find anywhere to upload this or adjust the package contents of Notability.
Page 1 / 1
Mobile Device Apps ---> Notability ---> App Configuration
Paste the plist contents into that box.
I thought it might be that but I got an "Incorrect Format Error" when I tried that, so that's when I came here.
Here's the code:
<plist version="1.0">
<dict>
<key>Giphy Allowed</key>
<false/>
</dict>
</plist>
The solution was to remove the header tags:
<dict>
<false/>
</dict>
Thanks for the help!
