Hey there, we're in the process of completely eliminating User-based deployment and just wondering if it would be wise to un-scope the users that we'll be switching from user to device deployment under the VPP invitation tab. This will probably prevent that pop up that shows up to assign VPP content if you launch Self service if I understand this tab correctly.
Also, I'm worried about the iPads that already accepted the VPP invitation in the past. If I unscope the apps under the user tab on the said iPads, will this trigger a prompt for an iTunes account?
Thank you in advance!
Be the first to reply!
