Forgive me if this has been addressed....
Would anyone know what scripts / commands Jamf is running on the backend, of this "baked-in" policy?
"Disable FileVault for Local Admin Account..."
I'm curious if Jamf is using the:
• fdesetup command - ONLY affecting FileVault
• sysadminctl command - disabling FileVault & Secure Token
Reason: Our local admin account appears to be losing its Secure Token, around the same time it's removed from FileVault, and I'm having a hard time pinpointing exactly 'when & where' that happens. I haven't found anything in our scripts that correlates to the issue.
@nic.karas Thanks for the FYI! This is awesome, looks like Jamf looked into it and acknowledged the problem, so its on their radar (PI-006768).
