I'm looking for a way to get the username and serial number from a user's iPad to be able to send it to a form (PDF, PHP, etc) for their user agreement. I want to be able to do this programmatically without much user interaction. From what I've seen it is possible to do with a configuration profile, but the documentation for that process is lacking. All the information is in the JSS server I need to extract it on a per user basis.
Page 1 / 1
I think you'll be able to use the API to get this done. Hit https://myjssurl.com:8443/api
