After building a new image using the updated 10.12.6 OS X when I try to image a iMac (Retina 5K, 27-inch, 2017) It puts the image down and after a reboot it sasy that Casper is finishing up the image but then after it reboots it is stuck on the login screen and no joined to the domain or using the local admin account, meaning the "Adobe" login that jamf uses is not logging in the Mac thus leaving it stuck. Anyone else having this issue?
Be the first to reply!
