Is anyone else doing what IBM is doing when the system is first enrolled? The progress screen when all the software is being installed is great. Any thoughts on scripts?
There is a big thread about this already : )
https://www.jamf.com/jamf-nation/discussions/17467/ibms-enrollment-screen-recreated
C
Is there anyway we could convince IBM to open-source their application?
@gachowski Thanks!!! I love the new custom setup that they're doing though.
Yeah we do it. We launch a swift built application to parse the jamf.log during enrollment and update the user.
This is ours...
@DanielN is this one that you could share with the rest of us that don't have swift developers or skills? I wrote one in shell script but it not anywhere near as good of course.
@DanielN That would be awesome if you could share that with the community. Minus any information related to your company of course.
Unfortunately, like IBM I can't share the code. All I can say is we used swift and parse the JAMF.log in real time. We had two interns that knew nothing about swift nor Casper create this in about 6 weeks.
@DanielN If you can't share the code, can you share some good resources for learning to make my own version of your Enrollment Screen?
@mlavine Just in case you didn't see it, I have an open source screen that can help you get started.
https://github.com/jason-tratta/ProgressScreen
