Really intrigued by the CIS scripts from the session, but some notes/context would really help me decipher them, and since we're headed to an audit soon while in the middle of switching our config/baseline management to Casper (uh... "Jamf Pro"), I'd love to get this in place sooner than the release of the session videos if possible.
(and yes... I lobbied my employer for 7 months to go to JNUC without success, or I would have my own notes... sigh)
@Taylor.Armstrong Happy to provide any additional context you might need. The slides are posted:
https://www.jamf.com/jamf-nation/events/jnuc/2016/233/digging-into-security-compliance-and-reporting?view=resources
And the Github repo has the scripts/general notes: https://github.com/jamfprofessionalservices/2016_JNUC_Security_Reporting_Compliance
Beautiful, thank you so much @kenglish ! so much more elegant than my own approach, I grabbed the scripts yesterday but needed some context to understand the implementation a bit better... the slides help a lot!
@kenglish Thank you very very very much !!!!! Another great Jamf GrandSlam !!!!!!
C
Just a heads up but I got an error running the script 1_Set_Organization_Priorities.sh until I put "" around the $dir in the if statement on lines 43 - 45, gave me an error that the folder was not found. Not sure if it was just me. Hope this helps others.
if [[ ! -e "$dir" ]]; then
    mkdir "$dir"
Thanks @rlandgraf - I'll be updating this weekend!
