We are using DNS for our JAMF Pro/JSS server but will be changing it's public IP to a private IP. From what I read thus far I shouldn't run into any problems and should be able to just make the IP change. Am I missing something? I just want to double check with you pros.
If you have anything pointing directly to the old IP, it will break. So long as everything is based on Host name and DNS resolves the host name to the new private IP (and is accessible by the device!), you should be good.
