"Apply to enclosed items..." via script
  • February 27, 2020
  • 17 views
akamenev47
Sorry if there is already discussion on this, I could not find.
Is there a way to somehow re-apply "Apply to enclosed items..." via Terminal onto certain folder?
  • February 27, 2020
-R after many commands will propagate the change downward from that directory- i.e.:
chmod -R 755 /Volumes/yourVolume/yourFolder
akamenev47
  • February 27, 2020
@SGill, tried that, however it does not apply the same permissions to folders and files inside the "main" share folder. I did not include the /Volumes/yourVolume/ info, just applied the chmod command directly to the folder, not sure if that matters here.
  • February 27, 2020
You'll have to use a combo of both chmod and chown to get things the way you want. See this:
Permissions-Tech Republic
