hi - i'd like to know which users use a certain application between certain dates.
for example, which user(s) use cisco anyconnect app between jan 1 to jan 17 2018.
how do i set this up? thx
Those logs may be easier to find within your Cisco appliance, The any connect app is configured to run at startup a lot of the times so you may get a lot of false positives
