Can anyone shed some light on how Jamf looks to see if Adobe Acrobat Reader/Pro is installed? It's showing as installed on all machines in my environment even if its not installed. For the machines that have it installed, it shows a version number, but if its not installed it just says "Unknown".
I'd be happier if Jamf just didn't even show Adobe Acrobat as being install as its not installed. Anyway to fix that?
Be the first to reply!
