While most of our machines are working with 802.1x... I have one machine (that I know of) that won't connect.
I tried removing all configuration profiles from jamf, but when I plug into ethernet, it'll give me an authentication failure. On a working machine, it'll show "default". (as shown in image below)
On this particular machine, it just says "Network". Does anyone know where this "network" configuration could be coming from? From past experiences, Network is configured with you have a configuration profile with the network payload configured..but I've removed config profiles.
Be the first to reply!
