I have already factory wiped this device and setup fresh last week with 10.14. I created an Apple ticket and they said a factory wipe would be the best way to fix.
The issue my caps lock light doesn't come on. This is the same for a external Apple Bluetooth keyboard. It was working fine, but today again the light doesn't work.
This is a 2018 MacBook Pro 15inch DEP Mac.
Any ideas on how to fine the app or setting using this issue.
List of apps installed:
Microsoft Excel
Adobe Acrobat Reader DC
App Store
Apple Configurator 2
Automator
BBEdit
BetterSnapTool
Bomgar Representative Console - support.truemfg.com
Books
Calculator
Calendar
Chess
Cisco
Company Portal
Contacts
Dashboard
Dictionary
Enterprise Connect
FaceTime
Firefox
Font Book
Google Chrome
Home
Image Capture
iTunes
Jamf Pro
Karabiner-Elements
Karabiner-EventViewer
Keynote
Kyocera Print Panel
Launchpad
Mail
Maps
Messages
Microsoft OneNote
Microsoft Outlook
Microsoft PowerPoint
Microsoft Remote Desktop Beta
Microsoft Teams
Microsoft Word
Mission Control
News
Notes
Numbers
OneDrive
Pages
Photo Booth
Photos
Preview
QuickTime Player
Reminders
Remove Sophos Endpoint
Safari
SecurID
Self Service
Siri
Skype for Business
Sophos Endpoint
Sophos Endpoint Self Help
Stickies
Stocks
System Preferences
TextEdit
Time Machine
Utilities
VMware Fusion
Voice Memos
My first question would normally be: Does it happen regardless of what user is logged in? But since you factory wiped it, I would assume that is not relevant. (but it's still something to consider)
My second question would be: Do you have a config profile going to this machine that could be causing this behavior?
Third question: when you press the caps lock key and type, does it actually type in all caps or does it not function at all?
question #4: Have you tried zapping the PRAM (or reset PMU/SMC/whatever Apple is calling it this year)? I've seen that fix purely hardware related issues like the Caps Lock light.
EDIT: the light doesn't work on ANY keyboard? built-in, bluetooth, or USB? See questions #2 and 4
1.My first question would normally be: Does it happen regardless of what user is logged in? Only my account which is a local admin
My second question would be: Do you have a config profile going to this machine that could be causing this behavior? Not that I know of
Third question: when you press the caps lock key and type, does it actually type in all caps or does it not function at all? Yes it does work just no light
question #4: Have you tried zapping the PRAM (or reset PMU/SMC/whatever Apple is calling it this year)? I've seen that fix purely hardware related issues like the Caps Lock light. Yes didn't seem to do anything.
EDIT: the light doesn't work on ANY keyboard? built-in, bluetooth, or USB? See questions #2 and 4 Doesn't work on any keyboard
If you factory wiped it but the problem is still localized to your account and no others, I can presume you are restoring your files from a backup and the problem keeps following you. If your account is the only one that's affected and all other accounts are fine, then it has to be something in your ~/Library/Preferences/ You may want to look at anything relating to keyboards like com.apple.HIToolbox.plist or any logitech driver files (if present) Move that file out to your desktop, then logout and login again. See if it helps.
I only restored my Desktop, Docs, Pictures, etc via OneDrive sync
I have found the issue Karabiner-Elements is causing the issue. When the app is closed everything works fine.
