I take care of 4-5 Mac labs in a high education environment. We're still on serialized Adobe CC 2018 for the moment and will switch to shared device licenses in a month or so. Near the end of the semester I disable my data clean-up script so disks tend to get close to being full. However, this year I'm finding the culprit in many cases is Adobe After Effects caches, typically in this path:
~/Library/Caches/com.adobe.AfterEffects
I'm debating writing a logout script to delete everything in this path. Has anyone else come up with a better solution? Cheers...
