Hello, apple recently pushed iOS iPad 13.4 out to iPads.
It appears that if we want to use iMovie app, I need to have the operating system updated to 13.4
some of my devices state the following message
your iPad is running the latest software update allowed by your administrator.
where do I change the setting to allow the latest update?
thanks
sprovost
Hi @sprovost ,
I'd start by going to Mobile Devices>Configuration Profiles. When you are there check all of your profiles for the Defer software update for restriction under the iOS and tvOS > Functionality tab
shaquir: thanks! will check out the areas you suggested.
sprovost
