I have a series of issues I'm running into in my upgrade testing from JSS 8.62 to JSS 9.0. I'll post each issue separately for sanitys' sake. FOr this series of issues: an "upgrade" is actually installing JSS 9 on a test server, restoring a 8.62 DB, then launching the WebApp to upgrade tables. I did not do an inplace upgrade since we are going to migrate server platforms and start from v9.0 on the new server.
Issue 3 - All Inventory display items were wiped out when we upgraded. Also cut and dried. Search results show the computer name and links to computer details. The other 12 columns we had set as default view did not migrate over. I can manually add these fields in the inventory display settings, but c'mon.
