What is the best method to update the NetSUS installation of Reposado. I don't think a "git clone" is best as the directory layout is from Greg's repo vs. /var/lib/reposado on NetSUS. Would a simple curl -O work? Of which files?
- Justin
(Reposado GIT repo: https://github.com/wdas/reposado )
