Anyone know how to remove this VPN Settings?
It is from user-level profile. I completely remove all profile include MDM Profile, but the VPN setting still there!
The remove button also is disable!
I attach all screenshot.
I even try delete in /var/db/ConfigurationsProfile (disable csutil), still the VPN Settings there!
Page 1 / 1
Hi @faizal_kamarudd,
I've only seen your tread now. Is your problem still current?
Jamf writes in the Admin Guide:
"Removing a computer from the scope of a user-level profile prompts Jamf Pro to remove the settings applied by the profile the next time the computer checks in with Jamf Pro while that user is logged in."
https://docs.jamf.com/10.28.0/jamf-pro/administrator-guide/Computer_Configuration_Profiles.html
If I understand it correctly, that means: the user has to log in to the computer again so that the profile is removed.
