I am working on a triple boot system and I need to write a directory to the Preboot partition of each of the drives. I know how to do it for a mounted volume. mkdir /Volumes/Preboot but as there are three different ones and they are not mounted how do you write to it when they are not mounted and have different and there for do not have different mount names?
Be the first to reply!
