I'm playing around with AutoRest (Github), and a number of errors are being generated.
Has anyone had any success with this?
Same. No luck as yet. I tried modifying the json schema a bit and got past some of them, but it seems like the schema is not being properly generated.
It looks like AutoRest is not supporting the 'OneOf' and 'AnyOf' pieces of the swagger doc. I'm guessing this is what's causing it to fail.
