My Static Computer Groups are obviously in alphabetical order.
But when scoping a policy, under Computer Groups they are not listed in alphabetical order but instead appear to be in the order they were created.
I'd show you a screenshot but there a lot of company names in my groups so you will just have to take my word for it.
This is not ideal and doesn't seem like it would be a lot of work to fix.
Thanks
Just click on the word Name at the top of the column and it will sort them into alphabetical order. Its the same in Jamf Remote when you look for computers to add. they will be in the order created, which will be the computer ID number order.
