Hi All
Does anyone know how much space the updates take?
We are looking at provisioning a LUN to a manual install of the NetSUS appliance but are unsure of how much space it will need. Also need to provision enough for future proofing.
If anyone has everything downloaded could they post up the size of the repository?
Many thanks
Oli
I'm currently at 263GB for all catalogs.
You should plan enough headroom, those voice updates take up a lot of space...
sudo du -hs /Library/Server/Software Update/
195G /Library/Server/Software Update/
