Local High School Tech here. We deploy apps via Self Service to students who are standard users and some apps will occasionally check for updates automatically. If there is an update available the app will prompt the standard user to enter Admin creds. This is a problem as you can imagine. Is there a setting in the policy, or someway to use PPPC to configure the device to allow the app to update with the standard user? Most of these devices are MBAirs running 10.15.7. Thanks in advance for your help!
Keith
Be the first to reply!
