My organization is planning a refresh which will take place later this summer. The current plan is to leverage Code42 to migrate the user data. I would like to avoid bringing over the user library as that data has been carried through Migration Assistant for past several refreshes. I would like to grab a couple of items which Code42 is not backing up including bookmarks, keychains, printers, and email profiles for Outlook and Apple Mail similar to USMT for Windows.
Has anyone performed a refresh using Code42? If so, what kind of obstacles did you encounter? What did you wish you knew before you started? Which tools did you find to be useful?
Be the first to reply!
