Hi all,
Not sure if I am missing something simple. Where can I specify a username for a WiFi Config Profile on iPads? I used to use Apple Configurator but do I still need to do that to make the profile with a username and password to auto join to a SSID? I'd rather not use Configurator.
I only see that I can specify the password but not a username.
Thanks,
Pete
Looks like you need to change the security type.
We use WPA2 enterprise. With this you can specify a username and password for EAP, or utilize TLS with a certificate if you set that up as well. Not sure what your company is running, you might want to run that by your networking team.
