Does anyone have a script of config profile setup to set the URL Homepage in Firefox? I had a script that did work with the older versions but it is not working with version I am running (91.0). Does anyone have a simple resolution to this? Thanks!
If looking for a configuration profile, you can use the "Application and Custom Settings" payload, and paste a json schema for Firefox in. I've used this method for config profiles for browser settings.
https://github.com/Jamf-Custom-Profile-Schemas/JSON-Schema-for-Jamf-Pro-Applications-and-Settings-MDM-Payload/blob/master/Mozilla/Firefox.json
