Hello All,
Wondering if there are any suggestions for a good ipad utilization report/tool? I find this a bit interesting as if there is/was a way to utilize screen time on a enterprise scale that would probably be the perfect solution. On computer side I was able to use app utilization reports on applications that auto run in the back ground but was not confident the same approach would be accurate on the ipad side.
Thanks in advance for your input
Jeff
Be the first to reply!
