Hi!
We're running JSS 8.6, and despite "Test the connection" under Settings>
JSS Settings>GSX Connection giving the positive reply "GSX test was successful," we can't get it to work from Inventory>purchasing. In that case we just get "GSX Lookup was not successful."
Any suggestions why the test says it works and then it does not? Is a different port used for the test and the actual GSX connexion? We're running the Linux version on Red Hat Enterprise Linux Server release 6.2 (Santiago).
Thank you for any input,
//Martin
Solved. It was as I had guessed a GSX setup fubar on our side.
Still seeing this on our prod and test JSS v8.6—both on 10.6 Server. Can you elaborate on your GSX fubar (e.g. not setup w/ "Manager" GSX role, incorrect account name/password)? Pretty sure I've checked these things several times.
Here's a system.log snippet from our prod JSS while testing client details > Purchasing > clicking blue GSX search icon, which fails with "GSX Lookup was not successful."...
Mar 25 15:25:08 MyJSSHost com.jamfsoftware.tomcat[72139]: Mar 25, 2013 3:25:08 PM org.restlet.ext.httpclient.HttpClientHelper start
Mar 25 15:25:08 MyJSSHost com.jamfsoftware.tomcat[72139]: INFO: Starting the HTTP client
Mar 25 15:25:08 MyJSSHost com.jamfsoftware.tomcat[72139]: Mar 25, 2013 3:25:08 PM org.restlet.ext.httpclient.internal.HttpMethodCall sendRequest
Mar 25 15:25:08 MyJSSHost com.jamfsoftware.tomcat[72139]: WARNING: An error occurred during the communication with the remote HTTP server.
Mar 25 15:25:08 MyJSSHost com.jamfsoftware.tomcat[72139]: javax.net.ssl.SSLPeerUnverifiedException: peer not authenticated
Mar 25 15:25:08 MyJSSHost com.jamfsoftware.tomcat[72139]: at com.sun.net.ssl.internal.ssl.SSLSessionImpl.getPeerCertificates(SSLSessionImpl.java:352)
Mar 25 15:25:08 MyJSSHost com.jamfsoftware.tomcat[72139]: at org.apache.http.conn.ssl.AbstractVerifier.verify(AbstractVerifier.java:128)
Mar 25 15:25:08 MyJSSHost com.jamfsoftware.tomcat[72139]: at org.apache.http.conn.ssl.SSLSocketFactory.connectSocket(SSLSocketFactory.java:339)
Mar 25 15:25:08 MyJSSHost com.jamfsoftware.tomcat[72139]: at org.apache.http.impl.conn.DefaultClientConnectionOperator.openConnection(DefaultClientConnectionOperator.java:123)
Mar 25 15:25:08 MyJSSHost com.jamfsoftware.tomcat[72139]: at org.apache.http.impl.conn.AbstractPoolEntry.open(AbstractPoolEntry.java:147)
Mar 25 15:25:08 MyJSSHost com.jamfsoftware.tomcat[72139]: at org.apache.http.impl.conn.AbstractPooledConnAdapter.open(AbstractPooledConnAdapter.java:108)
Mar 25 15:25:08 MyJSSHost com.jamfsoftware.tomcat[72139]: at org.apache.http.impl.client.DefaultRequestDirector.execute(DefaultRequestDirector.java:415)
Mar 25 15:25:08 MyJSSHost com.jamfsoftware.tomcat[72139]: at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:641)
Mar 25 15:25:08 MyJSSHost com.jamfsoftware.tomcat[72139]: at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:576)
Mar 25 15:25:08 MyJSSHost com.jamfsoftware.tomcat[72139]: at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:554)
Mar 25 15:25:08 MyJSSHost com.jamfsoftware.tomcat[72139]: at org.restlet.ext.httpclient.internal.HttpMethodCall.sendRequest(HttpMethodCall.java:332)
Mar 25 15:25:08 MyJSSHost com.jamfsoftware.tomcat[72139]: at org.restlet.engine.http.adapter.ClientAdapter.commit(ClientAdapter.java:117)
Mar 25 15:25:08 MyJSSHost com.jamfsoftware.tomcat[72139]: at org.restlet.engine.http.HttpClientHelper.handle(HttpClientHelper.java:110)
Still not sure logs refer to GSX or internal proxy auth error.
For anyone else who might benefit, here's a summary of resolution to my GSX lookup issue...
  1. JAMF TAM identified one GSX option unchecked, "Can check Coverage/Warranty"—despite the "Manager" role and "Can access Web Services", which was already set. Seems obvious in hindsight, but there was also a proxy component, too...
  2. Our standard proxy PAC .js required unchecking, then setting Web proxy and Secure Web proxy (both w/ DOMAINaccount and password auth settings).
Working like a charm now.
I'm seeing "GSX lookup was not successful." errors now, exactly as described by original poster.
GSX connection tests work fine from the JSS. Certificates are valid etc. I can also log into the GSX site manually, and my AST Diagnostic Gateway GSX account works, too.
This is a relatively new issue, as I was in GSX checking purchase info via the JSS last week. No network changes have been made. Affects all my admin JSS accounts, thus not a ACL permissions issue.
Casper 9.81
@dstranathan Me too!
GSX test are successful. In the past 7 to 10 days, looking up individual devices both old and new, are resulting in "GSX lookup was not successful."
EDIT - More information has been posted here: related JAMF Nation Discussion
