Welp! after 2 months, I can say with even more authority that I wish I knew what I was doing!
Here's my current situation:
-Just renewed the Jamf subscription
-Zero Touch is in what I consider a "FUBAR" state: The order of application installs, policy executions, configuration profiles needs to be redone
-triggers make no sense
-Polices are uncategorized
-Sites are possibly not being the best used, organized, or named
-Categories are not being best used, organized, or named
-Some form of user notification (Octory, DEPNotify, IBMNotify?) needs to be set up
-think there are policies that are colliding and causing issues
-there are programs that are getting installed that don't need to be anymore
-installed programs sometimes generate popups, which tells me they haven't been installed using the right switches in the command line
-Policy execution sequencing is broken
My question is this:
There's no easy way I've found to get a "fresh start" without causing significant impact to users. How have you successfully rebuilt your Jamf instances when they are dysfunctional? Or have you all been lucky and gotten to build yours correctly from the beginning, or not had to rebuild someone else's incomplete work?
