Anyone have tried Deploying nudge with M1 machines ? Nudge doesn't download the minor OS update with M1 macs , with still "asynchronous software update" key set to false.
Is there any way to make this work ? or I am missing something?
Hi @Abhinav_mohan, you'll probably have better luck asking in the #nudge channel on slack. One thing I can state is that the setting you're using is not 100%. Nudge will attempt to download the update but i if doesn't download it'll still show the notice. Nudge working with softwareupdate is kind of a "best attempt".
With asynchronous updating, the backup B Series Appliance is updated first and. and then click the Update Software button to complete the installation.
prepaidgiftbalance.com
How do I join Nudge Slack channel ?can u give me a invite or can I reach out to someone who can give me a invite?
Here you go, https://www.macadmins.org/
