Hi all,
I have had zero luck integrating RSA SecureID as an SSO provider into JamfPRO (cloud). The support should be there - https://community.rsa.com/t5/securid-integrations/jamf-securid-access-implementation-guide/ta-p/640986#Integration_Configuration_Summary
When configured I only get the response "Single Sign-On error". I have turned on debug logging in Jamf Pro Server Logs but it does not log any *saml* events there to help with the investigation. Any pointers?
Update: IDP initiated flow does not work, but SP flow does work. Which is very strange
