We would like to report on battery levels on iPads and send an alert when the level falls to a certain point. Although the battery level is reported, we are having trouble finding the criteria when setting up the smart group.
We'd also like to gather the reports more frequently. I found this script:
https://jamfnation.jamfsoftware.com/viewProductFile.html?id=209&fid=571
But it looks like it pulls down the entire inventory and loops through it. I'm wondering how that will scale to thousands of iPads.
Thanks,
-- jmca
Be the first to reply!
