Has anyone else had issues with 10.5.2 and Composer 5.11? Every time I try
to create a .pkg file from a DMG image (through the conversion process) I
get a 'Exception of class NilObjectException that was not handled' error and
then composer quits. This only started happening when I upgraded to 10.5.2.
Here is what I have in Console log for Composer around this time:
Mar 19 07:19:16 localhost kernel[0]: USBF: 2.635
CSRHIDTransitionDriver[0x9a82600](IOUSBCompositeDevice)
GetFullConfigDescriptor(0) returned NULL
Mar 19 09:25:44 TECH-MP-02 authexec[12456]: executing
/Applications/Casper/Composer.app/Contents/MacOS/Composer
Mar 19 09:25:45 TECH-MP-02 com.apple.launchd[474]
([0x0-0x9c09c].Composer[12452]): Stray process with PGID equal to this dead
job: PID 12456 PPID 1 Composer
Mar 19 09:25:46 TECH-MP-02 [0x0-0x9c09c].Composer[0]: SystemFlippers: didn't
consume all data for vers ID 1 (pBase = 0x28503730, p = 0x28503744, pEnd 0x2850374b)
Mar 19 09:25:46 TECH-MP-02 defaults[12458]: Domain
com.jamfsoftware.composer does not exist
consume all data for vers ID 1 (pBase = 0x28502dc0, p = 0x28502dd4, pEnd 0x28502ddb)
consume all data for vers ID 1 (pBase = 0x28508c40, p = 0x28508c54, pEnd 0x28508c5b)
Mar 19 10:57:37 TECH-MP-02 authexec[20377]: executing
Mar 19 10:57:38 TECH-MP-02 com.apple.launchd[474]
([0x0-0xc40c4].Composer[20375]): Stray process with PGID equal to this dead
job: PID 20377 PPID 1 Composer
Mar 19 10:57:38 TECH-MP-02 [0x0-0xc40c4].Composer[0]: SystemFlippers: didn't
consume all data for vers ID 1 (pBase = 0xe76f60, p = 0xe76f74, pEnd 0xe76f7b)
Mar 19 10:57:38 TECH-MP-02 defaults[20379]: Domain
consume all data for vers ID 1 (pBase = 0x28502220, p = 0x28502234, pEnd 0x2850223b)
consume all data for vers ID 1 (pBase = 0x28508260, p = 0x28508274, pEnd 0x2850827b)
And for package maker:
Mar 19 10:57:52 TECH-MP-02 sudo[20426]: jhalmanr : TTY=ttys002 ; PWD=/ ;
USER=root ; COMMAND=/Developer/Applications/Utilities/PackageMaker.app/Contents/MacOS/Pa
ckageMaker -build -p /Applications/Casper/Temp/SFT-QRK-QuarkXPress_7.31.pkg
-f /Volumes/SFT-QRK-QuarkXPress_7.31 -b /tmp -s -v -i
/private/tmp/Info.plist -d /private/tmp/Description.plist
Mar 19 10:58:20 TECH-MP-02 PackageMaker[20426]:
CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon
in dictionary.
Mar 19 11:07:39 TECH-MP-02 sudo[21359]: jhalmanr : TTY=ttys002 ; PWD=/ ;
Mar 19 11:08:07 TECH-MP-02 PackageMaker[21359]:
in dictionary.
Any takers?
---<o><o><o>---
Jesse Almanrode
'Sr. Graphic Systems Administrator'
MIS Technical Services
Cabela's Inc.
308-255-2625
jhalmanr at cabelas.com
I had the exact same problem this morning on a 10.5.2 client. Worked on 10.4.11. At least it is not just me!
Nathaniel Lindley
Learning Systems Specialist
Educational Technology
Saint Paul Public Schools
Saint Paul, Minnesota
nathaniel.lindley at spps.org
phone: 651-603-4929
I am unable to reproduce this with a simple package. Worked fine. What is the software title?
Are you doing this on a machine that has Xcode dev tools installed or not?
10.5.2 on a Mac Pro, Composer 5.11
Craig
I installed Xcode 3.0 and I did get the same error.
Composer doesn't even recognize Xcode 2.5...nice. =)
So you aren't losing your mind.
Craig
