I am trying to create an Extension Attribute that will show the attached thunderbolt display's SN#. I know how to get the info from the command line using /usr/sbin/system_profiler | grep "Display Serial Number"
I have tried to create the Extension Attribute with no luck. Below is what I am using and it is just returning result and the SN.
Thanks
RIchard
result=/usr/sbin/system_profiler | grep "Display Serial Number"
echo "<result>result</result>"
Looks like you're forgetting a dollar sign for the $result variable.
On 11/30/11 6:07 PM, "San Fran Geek" <sanfrangeek at gmail.com> wrote:
William Smith
Technical Analyst
Saint Paul, MN
(651) 632-1492
This has worked for us....
echo "<result>$(system_profiler SPDisplaysDataType |grep "Display Serial
Number" |awk '{print $4}')</result>"
Thanks,
Brian
Using the above as an example I'm really interested in an extension attribute that will actually list the output of "system_profiler SPDisplaysDataType" but playing around with greps output, removing grep altogether, etc is producing skewed results in terminal and no results in EA in Casper.
I'm learning as I go with scripting as this was never a big part of my previous job so I've been McGyver'ing scripts with good results, not so much with this though, any help or idea would be appreciated.
Try this out:
system_profiler SPDisplaysDataType | grep -e "^ {8}[A-Z]" -e "Display Serial Number" | sed 's/^[ ]*//' | sed -e :a -e '$!N;s/ Display Serial Number: / /;ta' -e 'P;D'
If you want to add to it:
system_profiler SPDisplaysDataType | grep -e "^ {8}[A-Z]" -e "Display Serial Number" -e "Main Display" | sed 's/^[ ]*//' | sed -e :a -e '$!N;s/ Display Serial Number: / /;ta' -e '$!N;s/ Main Display/ Main Display/;ta' -e 'P;D'
@sean
Thats amazing. There is no way in hell I would've ever got to that as being my end result of trying to figure this out.
Dumping that in to terminal or creating shell script and running it locally works 100% but putting that into Casper as an extension attribute is still no bueno, is there anything i'm missing?
result=`system_profiler SPDisplaysDataType | grep -e "^ {8}[A-Z]" -e "Display Serial Number" | sed 's/^[ 	]*//' | sed -e :a -e '$!N;s/
Display Serial Number: / /;ta' -e 'P;D'`
echo "$result"
Does it needs to be line separated for casper to recognize it? Terminal doesn't seem to mind copying/pasting that in directly. Sorry for hi-jacking @rdagel's thread, hopefully there's other casper users out there that will find this informative.
The result has to be a tag
derp.
thanks @sean, in all previous attempts i had my tags but for whatever reason decided they were useless this go around. much appreciated.
