Hiya all,
I found the verb to install a package using the command line
jamf install ­package xyz.pkg
... but I get an error 'The package (xyz.pkg) cannot be found.'
I see in the jamf man pages that a ­path can/must be supplied to the binary,
since I didn't supply one I presume this is the stem of my error message but
am uncertain what 'path to', to supply to the binary.
Looked on the KB but found nothing about installing via binary.
Thanks and happy turkey day to the USA folks!!!
-P@
DISCLAIMER 11/26/2009
This communication is intended only for use by casper at list.jamfsoftware.com. It may contain confidential or privileged information. If you receive this communication unintentionally, please inform us immediately. Thank you. 180 has registered companies in the United States and in the Netherlands. 180 Los Angeles LLC . (180) 1424 Second Street, Suite 200 and 300, Santa Monica, California 90401, is registered with the trade register in the US in Delaware under file number 4260284 and the corporation's FEIN is 20-5982098. 180 Amsterdam BV (180) Herengracht 506, 1017 CB, Amsterdam is registered with the trade register in the Netherlands under number 34253037 and VAT number NL8161.54.673.B.01. The content of this communications is not legally binding unless confirmed by letter or telefax. Please note that 180 is neither liable for the proper transmission nor for the complete transmission of the information contained in this communication or for any delay in its receipt. Also please note that the confidentiality of email communication is not warranted. All services and other work provided by 180 are subject to our general conditions (supplier terms and conditions). The conditions are available for inspection at Herengracht 506, Amsterdam and at the Chamber of Commerce in Amsterdam. If you wish to receive a hard copy of these conditions, please send an e-mail with your address to info at 180amsterdam.com <mailto:info at 180amsterdam.com>
In the event you send to 180 any unsolicited ideas and/or materials (whether consisting of texts, images, sounds, software, information or otherwise) ("Materials") by e-mail or otherwise, 180 shall be entitled to use, copy and/or commercially exploit such Materials to the fullest extent, free of charge and 180 will not be bound by any confidentiality obligation in respect thereof.
Date: Thu, 26 Nov 2009 05:37:55 -0600
Hiya all, I found the verb to install a package using the command line jamf install ­package xyz.pkg ... but I get an error 'The package (xyz.pkg) cannot be found.' I see in the jamf man pages that a ­path can/must be supplied to the binary, since I didn't supply one I presume this is the stem of my error message but am uncertain what 'path to', to supply to the binary.
Hi Pat!
Not in front of my work computer right now, but I think the path you need to
specify is not to the JAMF binary but to the package file itself. You need
to tell the JAMF binary *where* the package is located.
Looked on the KB but found nothing about installing via binary. Thanks and happy turkey day to the USA folks!!!
Happily in a tryptophan coma. :-)
bill
William M. Smith, Technical Analyst
MCS IT
Merrill Communications, LLC
(651) 632-1492
What I do to accomplish the same thing is do a custom policy. I drop
the PKG file into Casper Admin, configure it with a priority number,
small description and then sync it to the Casper distribution points. Then in the JSS web interface I create a policy to install the PKG via
custom trigger, example - mycustompkg
Then from the command line I can either do this manually or script it
via a shell script
jamf policy -trigger mycustompkg
You may need sudo if you run it from the command line. Otherwise, if
done by a policy the casper ssh account should handle it which should
run as admin/root anyway.
Thomas Larkin
TIS Department
KCKPS USD500
tlarki at kckps.org
blackberry: 913-449-7589
office: 913-627-0351
chown -R us /.base
