I've been running into an issue with our DEP computers where when we unbox a brand new computer that is enrolled in DEP, it won't display the DEP/MDM screen during the initial account setup. I was able to determine the issue and have taken the steps to resolve it (if you're interested in the cause and resolution, let me know) but the only way to fix the issue for some of the computers is to run an internet restore (possibly a local restore). Anyway, my question is this...
Once the initial setup of a computer gets completed, a file is written to the drive to bypass the setup screen for all future startups.
/var/db/.AppleSetupDone
Is there a similar file for the DEP/MDM screen that appears in the Account Setup process?
Thanks for any help that can be provided!
Ross
If you want the Mac to run through DEP enrollment again post restore, delete
.AppleSetupDone
and
/Library/Keychains/apsd.keychain
/var/db/ConfigurationProfiles
@psliequ Thanks for your help! The bottom two commands appear to have done the trick! The .AppleSetupDone didn't exist because we hadn't completed the actual setup process but the other two did the trick. Thanks for your help!
@rosskivowitz We're interested in the cause and resolution you've uncovered.
We're seeing similar behavior to the problems listed in this issue and are already familiar with the commands to resolve it posted above.
Any insight you can provide would be helpful.
Thanks.
-max
@rosskivowitz how are you solving the users not seeing the remote management page at enrollment from a brand new box?
@lamador The following Terminal command may prove helpful to verify a computer's status:
/usr/bin/profiles show -type enrollment -verbose
@lamador If you're sure the Macs experiencing the problem where the Remote Management screen isn't being displayed are definitely in a PreStage Enrollment, you may be experiencing a problem Apple is investigating where some machines are failing to connect with the server that triggers the Remote Management process
@sdagley Yeah i saw that in another thread DEP/PreStage Issue - Macs not picking up PreStage
@dan-snelson I tried that. It showed that the laptop was enrolled but int never created a profile in jamf
if anyone is still having issues the following articles helped me:
  • https://github.com/micromdm/micromdm/wiki/Troubleshooting-MDM
  • https://www.jamf.com/resources/videos/under-the-hood-device-enrollment/
  • https://cultureamp.wistia.com/medias/gaiq4f540s
