Im wondering why it's showing failed for a policy installation when the primary DP is not available and it does an http failover? The software installs correctly after the failover, I would think the result would be a warning but not failed. Thoughts?
Executing Policy Adobe Acrobat XI Pro...
[STEP 1 of 2]
Downloading Adobe Acrobat XI Pro Installer.pkg...
This package is a PKG or an MPKG, and the index.bom file is not found. Attempting to open the package as a flat package...
Downloading http://server.com/CasperShare/Packages/Adobe%20Acrobat%20XI%20Pro%20Installer.pkg...
Error: Could not connect to the HTTP server to download Adobe Acrobat XI Pro Installer.pkg
Retrying using distribution point PRI1...
Downloading http://sever2.com/CasperShare/Packages/Adobe%20Acrobat%20XI%20Pro%20Installer.pkg...
Verifying package integrity...
Installing Adobe Acrobat XI Pro Installer.pkg...
Successfully installed Adobe Acrobat XI Pro Installer.pkg.
[STEP 2 of 2]
Running Recon...
I have the same issue.
Is this a bug of a particular version? I'm running 9.32.
Based on your post it sounds very similar to the issues we were seeing a while back and posted about in this feature request.
https://jamfnation.jamfsoftware.com/featureRequest.html?id=1601
