Has anyone else seen any issues with com.apple.mDNSResponder.plist go missing when doing a block copy Image of 10.10.4 (14E46) with Casper 9.65? I am noticing odd behavior that when my configuration includes any application in addition to the block copy OS dmg, when I log in the com.apple.mDNSResponder.plist is missing. If I remove the applications from the config and run the build again, the file is there. I did something as simple as creating a dummy package in composer that just copied a text file to /var/tmp and added it to the configuration and after the image, com.apple.mDNSResponder.plist was missing again. I can combine the block copy dmg with any of our scripts and we don't have the issue, it's only when we have a .pkg or .dmg installer included in the config.
Be the first to reply!
