Completely remove iBoss from MacBooks
  • December 2, 2022
  • 126 views
Hello all,
We're seeing iBoss causing issues when students are trying to load ANY page.
We no longer use iBoss and were attempting to move over to Linewize. It worked perfectly fine and then stopped. We've narrowed it down to leftover iBoss files somewhere on the machines.
If we use the iBoss uninstall script, it'll work for a short period, but then returns.
Does anyone have a script or know of anything that we can use to COMPLETELY remove any instance of iBoss without having to wipe the machines? Wiping the machines does resolve the issue.
TIA!
Best answer by mickgrant
You could try using a composer snapshot to find all changes that are made when iBoss is installed.
Once you know what is installed, you can hunt down anything that is getting left over with the uninstall script.
I would also double-check that there are no Config profiles and PPPC profiles that are still being applied.
1 reply
mickgrant
  • December 3, 2022
