We have JAMF Connect and the Kerberos SSO extension deployed and 1 particular user’s sso extension every 14 days seems to disconnect and you can’t reconnect or sign in unless you reboot. Has anybody come across this before? Running 12.6 on an M1 Pro.
Page 1 / 1
Why are you running both? Unless I am missing something, Jamf Connect to do all the Kerberos functions that KSSO can.
