Hello all.  I have a set of apple tv's that have been working fine without issue.  All of a sudden one of them decided to not advertise on airplay unless it has the configuration profile removed.  Any ideas?  I have wiped the device, updated, restarted.  When I exclude it from our scope it works fine.  No other apple tv's in the configuration profile scope are having any issues.
Has anything changed in your environment?
Is this affected Apple TV on the same network as others?
Have you tried to connect to the Apple TV from a different client?
Does the Apple TV have any other profiles installed?
Can you eliminate your network and connect it to a different network (even a different physical site)?
