Looking for a computer extension attribute to check MAU Version in Mac
Take a look in Patch Management. You can track it there, or look at the EA that it is using.
Just add a custom search path to your inventory collection settings to collect apps from "/Library/Application Support/Microsoft". Then you'll have "Microsoft AutoUpdate.app" listed in your Application inventory for every Mac.
If you still want an EA, this will give you the version:
defaults read "/Library/Application Support/Microsoft/MAU2.0/Microsoft AutoUpdate.app/Contents/Info.plist" CFBundleVersion
I've added an MAU-Version Attribute and I wish to get a script which will read the installed MAU version and populate in the field.
Run a recon and it will populate.
Good thread see Don's information, within:
