I am needing to remove some obsolete login items from our classroom machines
I'm trying the following
#!/bin/bash -v
exec 2>&1
sudo -u $3 /usr/bin/osascript -e 'tell application "System Events" to delete login item "PCClient"'
sudo -u $3 /usr/bin/osascript -e 'tell application "System Events" to delete login item "fthf02.op.ac.nz"'
It works fine running it manually on a client but once I run it as a login policy I get
Script result:
43:53: syntax error: A class name can’t go after this identifier. (-2740)
Any ideas what I'm doing wrong?
Have you tried adding in a sleep 30? Perhaps it is running too quickly at login.
loggedInUser=$( ls -l /dev/console | awk '{print $3}' )
loggedInPID=$( ps -axj | awk "/^$loggedInUser/ && /Dock.app/ {print $2;exit}" )
/bin/launchctl bsexec "${loggedInPID}" sudo -u "${loggedInUser}" /usr/bin/osascript -e 'tell application "System Events" to delete login item "PCClient"'
Give this script a try. I got this a few months ago from a similar question someone else posed.
bpavlov: Be sure to test this technique under El Capitan. There might be some changes that affect this technique...
