Hi all,
so, pretty new to Jamf, but I work at a school where lots of random softwares are used frequently in specific labs.
One software we're using is OpenToonz, an animation software, and a FFmpeg plug in, which I have to point to a file path for OpenToonz to find the folder for. Problem is, this preference file is stored in /Applications/OpenToonz/OpenToonz_stuff/profiles/layouts, and generates a folder called "settings.usernamehere"
So, I can create the preferences file and move it to a specific path on scoped computers, but what I can't seem to figure out is how to create a file based off the name of the current logged in user, and place it in that specific file path. (i.e settings.currentLoggedInUser)
I assume a script is the way to go, but my googling has failed me this time around, and I'm a little out of my depth. Either way, appreciate any help you can give!
the below script will retrieve then currently logged in user, and create the needed path:
#!/bin/sh # variable and function declarations export PATH=/usr/bin:/bin:/usr/sbin:/sbin # get the currently logged in user currentUser=$( echo "show State:/Users/ConsoleUser" | scutil | awk '/Name :/ { print $3 }' ) # global check if there is a user logged in if [ -z "$currentUser" -o "$currentUser" = "loginwindow" ]; then echo "no user logged in, cannot proceed" exit 1 fi # now we know a user is logged in # get the current user's UID uid=$(id -u "$currentUser") runAsUser() { if [ "$currentUser" != "loginwindow" ]; then launchctl asuser "$uid" sudo -u "$currentUser" "$@" else echo "no user logged in" # uncomment the exit command # to make the function exit with an error when no user is logged in # exit 1 fi } # main code starts here runAsUser mkdir "/Applications/OpenToonz/OpenToonz_stuff/profiles/layouts/settings.$currentUser" exit 0
 you'd still need to decide how you wanted to call the script to run; simply you could advertise it in self service for users to run on demand or wrap it in a .command and deploy for users to run as needed or tie it to a launchdaemon to run every time somebody logs in.
The script also assumes that all users have permission to write to the ..../layouts path; something you could fix with chmod if that wasn't the case.
Your choice really. Hope that helps.
it just dawned on me that you said you wanted to create a file and not a folder; my apologies. the below version should make a file instead of a folder. Obviously remove the placeholder with the exact file contents:
#!/bin/sh # variable and function declarations export PATH=/usr/bin:/bin:/usr/sbin:/sbin # get the currently logged in user currentUser=$( echo "show State:/Users/ConsoleUser" | scutil | awk '/Name :/ { print $3 }' ) # global check if there is a user logged in if [ -z "$currentUser" -o "$currentUser" = "loginwindow" ]; then echo "no user logged in, cannot proceed" exit 1 fi # now we know a user is logged in # get the current user's UID uid=$(id -u "$currentUser") runAsUser() { if [ "$currentUser" != "loginwindow" ]; then launchctl asuser "$uid" sudo -u "$currentUser" "$@" else echo "no user logged in" # uncomment the exit command # to make the function exit with an error when no user is logged in # exit 1 fi } # main code starts here runAsUser cat << EOF > "/Applications/OpenToonz/OpenToonz_stuff/profiles/layouts/settings.$currentUser" <contents of file goes here> EOF exit 0
Great, I'll give this a shot!
You were right the first time, in that I need to create a folder, and then move a file there, but I think I have what I need to do automate the last parts. The folder creation and naming itself were the big challenges, so this is insanely helpful. Thank you!!
