Has anyone tried to disable iCloud Private Relay? I'm using the Plist below, but it only hides the iCloud Private Relay option in the iCloud settings and doesn't actually disable it. I still found it to be ON.
Has anyone else experienced this or found another way to disable iCloud Private Relay?
<plist version="1.0">
<dict>
<key>allowCloudPrivateRelay</key>
<false/>
</dict>
</plist>
